New member Username: Panther77Lakeville, Minnesota USA Post Number: 1 Registered: Aug-05 | Im getting a kicker L7 12 inch with a Kicker 04KX600.1 amp... should i go with the 2 ohm or 4 ohm sub???? please help i know nothing about impedence!!! |
Silver Member Username: LoudonPost Number: 280 Registered: Jun-04 | dual 4 wire it down to 2 ohms |
Silver Member Username: CnafetsPost Number: 143 Registered: Aug-05 | www.bcae1.com plenty of info about car audio. |
zook Unregistered guest | i agree get the 4 and wire it down |
Gold Member Username: JmloughreyFarmington, CT Post Number: 1325 Registered: Jul-04 | get the 4 and wire it down to 2 ohms if you amp can take it. If you plan on adding another one somewhere down the line in the near to distance future get the dual 2 so you can wire them together for a 2 ohm load. |
