Question regarding boomboxes (boombox forum is dead)
Username: Tmansdc
I want a good cd r/rw compatible boombox with qsound capability. (I have old sega cd games that support qsound that sound much better with qsound then regular stereo.) So what should I do?
Can someone recommend a new boombox that has qsound capability? Must be $100 or cheaper. Thanks.
Username: Edster922
Post Number: 1604
does it have to be a boombox or can it be a compact minisystem?
Username: Tmansdc
Post Number: 7
Sure, it can be a compact minisystem. Must cost under $100 though.
Username: Edster922
Post Number: 1651
This Sharp wasn't bad for the money and I think it has an alarm feature so it can be used like a clock radio.
http://samsclub.com/eclub/main_shopping.jsp?coe=0&oidPath=0%3a-23542%3a-23589%3a -44061%3a-44082%3a920466&mt=a&n=0&BV_SessionID=_SC_1956849389.1124953283_CS_&BV_ EngineID=ccchaddfhlghmdmcfkfcfkjdgoodflg.0
PS. I'm not a gamer so I have no idea what in the hell "qsound" is.
Username: Tmansdc
Post Number: 11
It says that has expired. Could you post another link?
And I hear Qsound is sometimes used for music cd's as well.
Username: Edster922
Post Number: 1685
go to their website and search for the model or item number.
Model: XLMP60
Let this 120W compact shelf system boost your energy level to the maximum. With its 5 CD changer and 45W subwoofer, music has never sounded so good. System is also CD-R/RW and MP3 playable. All these great features in one incredible unit.
Item: 464922
Sharp 120W Micro Shelf System $89.84
Features
# 120 Watt Micro Component System with 5 CD Changer and Subwoofer
# CD-R/RW and MP3 Playable
# 32 Track Programmable Music Selector for CD with random and repeat playback
# 6 mode Electronic Equalizer
# Clock Timer/Sleep Functions
# Remote Control
Product Specifications
# Power Output: Speakers: FTC: 37.5 W per channel + 45W Subwoofer
# Terminals: Headphone, FM/AM Antenna, Front Speakers, Subwoofer, Video AUX input
