Alpine F Indicator locked!
Username: Bobbybox
Hi
I've recently bought a new Alpine DVA-9860R HU and have been very pleased with it so far.
One problem: I can't seem to get rid of the "F" (F/SETUP) indicator in the display when I'm in DISC or AUX mode.
The F/SETUP key is supposed to toggle on/off and it does in TUNER mode no problem but not in the other modes mentioned above.
I've tried resetting the HU and disconnecting the car battery but I can't get rid of the problem.
I've been through the manual carefully (I think) and I can't find any reason why the F indicator shouldn't toggle properly.
Any thoughts please? I guess this problem could apply to other recent Alpine HU's too...
thanks
Bob
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9585
if you turn off the F indicator in Tuner mode, then switch to CD or AUX, does it come on again, or stay off?
Username: Bobbybox
Hi GlassWolf
The F indicator setting in Tuner mode doesn't seem to affect the CD/AUX mode. The F indicator is constantly lit in CD/AUX mode whether I set it to on or off in Tuner mode.
Very odd...
thanks
Bob
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9612
this is a brand new unit right?
before I start suggesting things, did you try calling alpine support? that'd be my first step.. just to cover your behind under warranty
Username: Bobbybox
It's brand new but although the F indicator remains lit I can't find any problem with sound or settings in any mode.
I'll just run an AI-NET cable to 3.5mm jack as an AUX input to my IPOD today and it worked beautifully first time.
I'm wondering whether the software has glitched or I have...
