JBL BP 1200.1 or JBL GTO 1201.1 II
Username: Camaro155mph
Post Number: 84
Which amp is better? I know the BP 1200.1 is older, but i can get it for like $50-75 less than the GTO1201.1 II
I'm am pretty much sold on the Orion H2, but...
With either of these amps, what would sound louder...
1 12" Orion H2 12.2 (Ported box)
1 Alpine Type X (Ported box)
2 12" Infinity kappa Perfects in a sealed box
My bet is the infinitys would have the best SQ, but worse SPL even though there are 2 of them. idk why i think that but i do. maybe becuz they are only 350 RMS each.
The alpine Type X would be the most well rounded SQ, SPL sub of the bunch.
The H2 would have the BEST SPL, but worst SQ... but i don't think the SQ is that bad...
Opinions???? thanks
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9403
the GTO is the better amplifier and if I recall, has a subsonic filter unlike the BP model.
the H2 is ok I guess but for the money, it's built weakly. I've heard of quite a few failures with those subs, and for $300-400 each you could get better subs for sure.
the type X would be the best choice, but sealed not ported. it's got too low of a Qts for ported enclosures. best SQ and decent SPL.
The Infinity subs aren't that great.. very low SPL output.. SQ is average.
Post Number: 85
Will the SPL with the type x and the GTO be better than my Current set-up? 2 12" power acoustik FUBR's sealed and a 880 RMS Power acoustik amp...?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9427
with one type X? hard to say..
fubr subs get fairly loud.. they just sound like poo
Post Number: 91
so the SQ will be way better than? What about the GTO with a ID MAX 12D@? GTO with Orion H2 12.2? Glass c'mon i know your the expert.
Username: Riebread77
Post Number: 579
ID max would sound ridiculous
