HELP WITH INSTALLATION PLEASEEEEEEEEE
Username: Stangz3
i have a 1994 eclipse and a pioneer deh-4700mp
i dont have the wiring harness adapter to connect my factory harness to my pioneer harness.... could i cut the harness of teh factory one so its just wires and then wrap the harness together?
Username: Infinity_addict
Santa Rosa, California USA
Post Number: 116
yah, you can cut the factory head off yer car's wiring and play "match the wires"! make sure yer factory wires have a bit of slack tho, othewise summing those wires together isn't gunna be fun.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9464
yes you can tape and solder, but it's not recommended
just go to sears and get a mid 90s mits harness for about $7, and a fit kit for that car to mount the radio.
simple, fast, cheap, neater, and easier to replace the radio later if need be
