New member Username: Necro1990Saint John, New Brunswick Canada Post Number: 1 Registered: Aug-05 | please give me in full detail what to do to eliminate trunk rattling, and with a high powered sub does it loosen any bolts or anything that should be tightened once and awhile, im new to this kinda stuff as u can tell |
Silver Member Username: BananakrillVallejo, California Post Number: 157 Registered: Jul-04 | Not only bolts but screws and nuts. You can sound deaden using some sort of sound deadening material. The most popular are: Dynamat http://www.dynamat.com/ eDead http://www.edesignaudio.com/category.php?type=damp&cur=USD Stinger Road Kill http://www.darvex.com/miva/merchant.mvc?Screen=CTGY&Category_Code=RK LizardSkin http://www.coollizard.com/default.html B-Quiet http://www.b-quiet.com/index.html Fatmat http://www.fatmat.com/ There are also expanding foams you can purchase at hardware stores. Make sure everything is tightened down. These products really work. I have a friend named Josh Conner. |
