Username: Subaruwrx163 Valley stream,
Valley sttream
Us
Post Number: 28 Registered: Aug-05
Tuesday, August 23, 2005 - 17:04 GMT 2 kciker compvr 10's, or 2 rockford punch p2's
Username: Southernrebel Monroe,
Louisiana
Post Number: 847 Registered: Mar-04
Tuesday, August 23, 2005 - 17:19 GMT compvrs
Valley sttream
Us
Post Number: 29 Registered: Aug-05
Tuesday, August 23, 2005 - 17:29 GMT what is the difference in sound quality, because if i get the comp vrs i will be running them wit the kicker 400.1kx amp How will tat sound??
Username: Tdbdadrummer Post Number: 39 Registered: Aug-05
Tuesday, August 23, 2005 - 18:44 GMT Wow, running the risk of clipping is all I can say. It will sound good at low levels, but you're getting tricky underpowering by 200W! I mean, if it were 50-100, it wouldn't be so bad, but that's 200!
Valley sttream
Us
Post Number: 32 Registered: Aug-05
Tuesday, August 23, 2005 - 19:11 GMT what do u mean by clipping, and how am i underpowering the subs are 400 rms and so is the amp
Username: Tdbdadrummer Post Number: 41 Registered: Aug-05
Wednesday, August 24, 2005 - 02:22 GMT Because, it's a mono amp. Even if you run your subs at with a combind ohm load of 2 ohms, that gets evenly divided among both subs. So 400WRMS/2 Subs = 200WRMS each. The subs are 400W RMS. Clipping is distortiong sent to the subs from an overdriven/cheap amp.
Username: James_g TN
Post Number: 81 Registered: Jul-05
Wednesday, August 24, 2005 - 02:43 GMT You need an 800w RMS amp for those subs. Assuming they are 4 ohm DVC, look for a mono amp that puts out about 800w RMS at 1 ohm.
Valley sttream
Us
Post Number: 33 Registered: Aug-05
Wednesday, August 24, 2005 - 02:56 GMT i thought that the subs were a combined 400watt rms not each 400
