Viper Programming Question
Username: Smith_erick
Greensboro, NC
Post Number: 8
Is there a way to delete the transmitters(remote) from a brain's memory, im trying to program my remote and i want to re-do it, and it won't learn its new codes, so how can i re-program the same remote?
I need to reprogram my Viper Ultra 800HF....can I get the link to where this information can be found. Thanks.
Username: Paradroid
Post Number: 15
You can delete all transmitters then you could reprogram it.
I think it depends on the model as to how you do it (seems to be either 9 or 12 in the programming table)
Theres a couple of manuals http://clubgtinorfolk.com/downloads/alarm-manuals/viper/
