New member Username: Mrmoe75
Post Number: 5 Registered: Aug-05
Posted on Can 4 MTX 6000 12" 4 ohm subs be wired to 1 ohm? If so, how? |
Silver Member Username: Sploosh56
Ohio
Post Number: 827 Registered: May-04
Posted on yes. just like that |
Post Number: 7 Registered: Aug-05
Posted on Hey thanx, would this be a good setup for a hifonics brutus 1500? I figure each sub would get about 375 watts each. Is this correct? |
Ohio
Post Number: 836 Registered: May-04
Posted on oh yea. that'll be loud. jsut make sure you don't run your subs to the point of distortion and if you use a ported box use a subsonic filter |
