Hello, I have the DLP 5063. I'm not sure which revision this is , but I was wondering what modifications or upgrades can be done to the 5063 to make it more dependable? In other words can you take parts from a 5078 and install them into a 5063 to make it work better?
FYI are you sure? The boxes look like they are the same size. When the technician worked on my TV. He basically told me that the TV has two main internal pieces. The housing for the light engine and then the housing for the DLP chip. If the box is the same, I would think, if both items were replaced the TV , in a global way, could be upgraded. Maybe I'm thinking too much like a PC technician. But maybe it will work.
FYI, thanks for this information! I purchased my 5063 for a pretty low price. Under 1500. Do you think it's worth paying the extra ($500.00 minimum) to upgrade to a new generation? What do you think about other brands in DLP? I heard JVC is really good. What do you think about Toshiba ? Maybe they have capitalized on Samsungs mistakes?
Actually, Samsung has capitalized on their mistakes.
The P63 you have is much better made than the one I bought last year. They had a Toshi lamp in mine that was quickly replaced with the better Phillips that I'm sure you already have. The color wheel is better in yours too.
I upgraded to the R67 for the increased contrast ratio and the 5th gen light eng. Also, I like the floating screen design.
It kills me that you paid under $1500 for the same set I paid $2800 for a year ago, but that's the nature of the biz. It's not too different than computers. Bought one in 98 and it was obsolete by 99. Still works fine, though. My P2 400mhz is still faster than my broadband internet connection.
JVC doesn't make DLP, but they have a very nice D-ILA LCOS coming out next month with a faster refresh rate than previous models. Pricey, though!
Toshi is not my favorite since their lamp failed in my Samsung in two months.
I thoroughly enjoyed my P63 and for the price you paid you have an excellent entry into HD. The HD picture is really very close to my R67.
FYI, Here's a tough one... I have the 5063 now(as you know) This dealer is selling a brand new Toshiba for the same price. I'm not sure if the technology or quality is better. But, maybe it has less bugs than the 5063 and maybe they upgraded their bulb. It's the Toshiba 52HM84. What do you think ?
