I need clean power
Username: Secretsoundz
St. Paul, Mn USA
Post Number: 12
Soon I'm getting a Hifonics 1605D class d 1600 RMS @ 1 ohm amp. Running 2 aw1200q's.
I drive a 92' mazda 929.
I have an old 4awg kit.
What do I need to assure plenty of clean power?
Larger than 100 amp inline fuse?
Do I really need another batt or cap?
I'm a bit of a beginner,
thanks
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9378
is that your only amplifier in the system?
1600 watts RMS is going to mean about 160A of current draw at full output.
you'll need a high output alternator rated for at least 200A, you'll need 1/0AWG power cable for the "big 3" and battery to amplifier, you'll also want to replace the stock battery in the car with a deep cycle like the optima yellowtop or similar.
that's about the only way you'll get clean power for that setup at high volume
St. Paul, Mn USA
Post Number: 13
Thanks Glasswolf,
I checked out sounddomain.com for more info
on the "big 3". I'll need to disassemble some stuff but it's seems like a need now.
I've got a new heavy duty battery but the alternator I was afraid of, If I clean up the wirung it might be ok.
I'll end up getting a 2 farad cap before an alternator.
Thanks
Username: Brynm
Prince Albert, SK Canada
Post Number: 102
Caps are just a band-aid fix. get the alt, it'll be money well spent. Check out Glasswolfs website www.wickedcases.com and look what it says about caps.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9405
well, the big three thing only helps if your car is so old that the wiring is corroded or worn down, or if you replace the alternator with a larger, higher current unit.
otherwise the factory wiring is able to handle all of the current the stock alternator can supply.
capacitors don't replace the need for an alternator..
here:
http://www.wickedcases.com/caraudio/capacitors.html
and
http://www.wickedcases.com/caraudio/charging.html
those explain why
