killerzracing Unregistered guest | http://www.torinocobra.com/guest_htm/travis_johnson.htm thats my car ok i want to install a second alternator to power a mb quart raa 1000 (1000rms @ 1ohm) but i know my stock alternator cant run that at all so i wanted to get a second alt any problems with doing it i know cost but wiring i was going to have a second battery just for audio visual equipment out back |
Silver Member Username: JaackdethUnited States Post Number: 551 Registered: Sep-04 | Your going to install a second one, or just upgrade? |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 9202 Registered: Dec-03 | the second alternator will be isolated and run only the car audio system and batteries for the system, so that's the alternator you'll need heavy wiring for. you'll also need brackets fabbed for the second alternator |
Gold Member Username: SubfanaticKy Post Number: 4710 Registered: Dec-04 | dont know how to do this sorry' hjust wanted to say, beautiful car |
killerzracing Unregistered guest | thanks subfanatic any one can else help |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 9424 Registered: Dec-03 | hey how much spray are you running on that motor, and what is it, a 460? just curious.. (what shot, or how many lbs/min) |
