Omnimount LCD Cantilever Wall Mount
ISH
I got one of these today, but they didn't include any screws or mounting hardware!
Anybody have one of these? Mine is for mid-sized LCD's, I was planning on using it to mount my Sharp 26'....I don't see how this thing isn't going to fall off the wall, the Sharp is a light TV, but the mount itself is heavy too...just 2 screws in a stud will keep this baby on the wall?
G_Trump
If you use a couple of 3" #8 or #10 screw, generally the home will fall before the tv does! Omni Mount products usuall come with all the hardware required amd have a great support team. Give them a call.
JTG
Does anyone know if the Omnimount U2 tilt wall mount can also stay flat against the wall without using the tilt?
Username: Louisa9
The dealer where you bought the things should be able to suggest appropriate stands.
Username: Project6
Post Number: 16115
That was in 2005, you think they would have figured something out during the past 7 years?
Username: Artorange
Pittsburgh, PA
I don't think so , lets wait another 3 years , we'll keep you posted.
Need to Register?
Forgot Password?
Enable HTML code in message
