Ipod wont connect to itunes
Username: Colshub
i have a used ipod mini (blue) off ebay. it has 700 somethin preloaded songs from the last preson that had it. i plug it in and this box coms up that says "put in the cd that came with it." so i do and it installs for a bit and then since i already have itunes it wont fininsh installing. someone plz help.
Username: Illuminator
Post Number: 1461
Which CD are you putting in? The iPod install CD? I believe it is asking for the music CD...
my i pod wont work. it does not download i tunes and has been saying do not disconnect for 24 hours now. whats wrong with it?
