About light dimming(not always it's because of the alt)
Username: Panamanian
Panama cityPanama
Post Number: 64
I read, that some cars (like mine) have a "slow power regulator".
For example, if you lights dimm when a BOOM! hits the subwoofer, it is not necessarily because of lack of amps...
You can try this by having a continuous BOOOOOOOOOOOOOOOOOOOOOOOOOOM (low note) for a long period of time (at least 5 seconds). and if your lights dimm, and dont come back to normal, then there'a weak current, if after half second it comes back to normal then, it's a slow power regulator.
In that SPECIFIC case is necessary a Capacitor?
(just to avoid the dimming, but knowing already that we have enough power).
whaddayathink?
Username: Scubasteve
Annapolis, MD
Post Number: 406
If you have a supposedly "slow power regulator" then you need to buy a HO alternator. Garunteed to solve the problem.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9243
you can replace the voltage regulator if it's external, but most are built into the alternator so you still need to replace that to fix the problem.
