Ok People I need your honest opinion
Username: Liquid_slap
Westland, MI
Post Number: 14
Is JVC some garbage?? I like the features some of their head units have. I need a head unit that is sirius ready and so far all I see is kenwood, clarion and JVC. I mean would a JVC be an ok choice or should I keep looking?
Username: Illuminator
Post Number: 1417
It's all right but you would be best off getting something better.
Why do you need a sirius ready unit? You can get a plug and play sirius receiver and all you would need is a headunit with an aux-in feature.
Westland, MI
Post Number: 15
the aux. input will be used for my Xbox.
Post Number: 1436
I see, then yeah, get something nicer. Clarion is great.
Westland, MI
Post Number: 16
Do you think the difference between the Clarion and the JVC is that noticable?
Post Number: 1438
No questions about it. Clarion is extremely better.
Westland, MI
Post Number: 17
Well I guess that settles it. Clarion units look so cheap and oldschool; but I guess if I want go sound quality, that is what I have to go with.
Post Number: 1439
What models are you looking at that seem cheap and oldschool?
Westland, MI
Post Number: 18
man all of those clarion units look like old tape decks with CD players in 'em instead. IMO
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 736
Not only will the Clarion sound better, it will last much longer.
I happen to think that the Clarion headunits look rather pleasing.
