Help please SA4200HD
Username: Casey
Post Number: 21
I posted this in another forum but didnt get any responses, any help is appreciated:
Well I finally got my HD working. The tech that came was a roaring disaster believe it or not didnt even know where to plug the outputs into my HDTV to get sound. Well anyway, I finally figured how to get it to display 1080I using bypass and the pic looks great. My panel is 720p and I was thinking that perhaps using its native resolution would give me an even better pic. Can anyone tell me how to set it to 720P? I would like to at least try it, thanks.
Wilson PIckett
After much fiddling with the 4200HD, I found the best results with this:
It's a two-part setting.
General Settings: Picture Format:Fixed
Quick Settings:Picture Format:1080i
You also have the 720 option which you are looking for.
