Need help with Amp
Username: Rayee
Hi, I could use some help. I installed a Jensen cd3010x into a 1995 Ford Taurus. The stereo worked for a short time, then quit. I was told I needed to bypass the factory amplifier. I'm not sure where it is located and what harness I would need to buy for this. I'd appreciate any advice.
Thanks
Username: Camaro155mph
Post Number: 22
factory amps are usually in the trunk under the carpeting, or under the back seat. Do you have another amp you are using or just the deck's amp?
