Difference between Toshiba 34HF84 and 34HF85?
Username: Gred
it's my understanding that the 85 is simply the more recent version of the 84... but it's priced significantly cheaper, so i was wondering if anyone knew what the differences in specs/features are?
thanks in advance.
The 34HF85 only has one tuner, so there is not any PIP, like the 34HF84 model.
waltchan
34HF84: Made by Toshiba
34HF85: Made by Orion for Toshiba
I just bought the 34HF85...4 hours ago - are there issues?
