New member Username: DaydreamernyPost Number: 1 Registered: Aug-05 | I recently bought a GEMINI Pro DJ Belt Drive Manual Turntable XL-120MKII. I chose this turntable as I am new with this. I was wondering if anyone could recommend a good compatible receiver for this turntable. I don't know what it should have to make it compatible or not. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1552 Registered: Mar-05 | You need to find something with a phono input. I think the NAD 320bee should have one, you might want to check into it. http://www.yawaonline.com/miva/merchant.mvc?Screen=PROD&Store_Code=YO&Product_Co de=NAD_C320BEE&Category_Code=AMP The HK 3480 certainly does have a phono preamp: http://www.jr.com/JRProductPage.process?Product_Code=HK+3480&JRSource=GAW.campai gnname |
Silver Member Username: Stu_pittNYC, NY Post Number: 426 Registered: May-05 | The 320BEE doesn't have a phono input. You could get a seperate phono pre-amp. Pro-Ject and NAD make very good one for about $100. |
Silver Member Username: Riches1Atlanta, GA US Post Number: 183 Registered: Apr-04 | Both Denon and Onkyo receivers have phono inputs. |
