Silver Member Username: KickerSlave lake, Alberta Canada Post Number: 142 Registered: Jun-05 | is spl the are movment in the cab or what |
Bronze Member Username: Infinity_addictSanta Rosa, California USA Post Number: 87 Registered: Jul-05 | SPL=sound pressure level. basically... loudness. |
Silver Member Username: KickerSlave lake, Alberta Canada Post Number: 144 Registered: Jun-05 | so the more subs with proper amperge in a small area would be better for spl? |
Silver Member Username: KickerSlave lake, Alberta Canada Post Number: 145 Registered: Jun-05 | or like this what would be louder truck or van with 4 12" 1000 watt amp each same every thing |
Silver Member Username: KickerSlave lake, Alberta Canada Post Number: 146 Registered: Jun-05 | just noticed i ment air not are is spl the air movment in the cab or what |
Silver Member Username: Thx_3417Post Number: 781 Registered: May-05 | Hears an example of the SPL, sound pressure level & db http://www.jimprice.com/prosound/db.htm http://www.termpro.com/dbdrag/ http://www.lightav.com/car/spl/subs.html http://www.termpro.com/ http://www.modaco.com/SPL_db_meterl-t224441.html http://www.splmeter.com/ |
Silver Member Username: Subzer0Richmond, KY USA Post Number: 715 Registered: May-05 | .. omg.. Spl= sound pressure level, the amount of sound given off by air movement of a sub, this has been said already in this thread and from now one please refrain from posting until you use a search option. Search is your friend. |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 9176 Registered: Dec-03 | STFW |
Silver Member Username: Thx_3417Post Number: 782 Registered: May-05 | Search is your friend, do you have any idea at all how much stuff is hear, hundreds if not thousands, Rigger post away if it was mentioned yesterday it can be just about anywhere on this forum. Get the picture? |
Silver Member Username: Thx_3417Post Number: 783 Registered: May-05 | If I started looking through the achieve section, I'll be call for the Samaritans? Get the picture? |
Anonymous | Why the he11 dont they bann Andy Summers everytime he post something it has to be with some stup!d azz pictures. Get out this forum you F@G. |
Silver Member Username: Subzer0Richmond, KY USA Post Number: 716 Registered: May-05 | Andy's Fine, leave him be. |
Silver Member Username: Thx_3417Post Number: 788 Registered: May-05 | Anonymous I'll post what ever I like, and when I like. Get the picture? |
Silver Member Username: Mikechec9Chicago/atlanta Post Number: 702 Registered: May-05 | http://realmofexcursion.com/videos.html |
