Bronze Member Username: SmallvilleSandy, Utah Utah Post Number: 28 Registered: Aug-05 | can somebody look on ebay at this item nuber 5797108785 the subs are called blue waves so if someone could tell me if there good or not and a good brand or not? thanks |
Silver Member Username: Thx_3417Post Number: 789 Registered: May-05 | Corey Is this the item, that you are talking about item # 5797108785. Blue Waves that's what I came up with and look smashing, so what's holding you back on them go for it. |
Bronze Member Username: QuickshotCharlotte, North Carolina U.S. Post Number: 79 Registered: Aug-05 | no dont get that sh!t they suck balls...pyle makes some of the worst sounding and overrated cra products ever..those subs will sound horrible and break down pretty fast |
Silver Member Username: Basshead86Ocala, FL USA Post Number: 329 Registered: Aug-05 | their quality is in the name lol you would be better off to go with a different brand |
Bronze Member Username: HardballElgin, Sc USA Post Number: 23 Registered: Jun-05 | haha, whoever gets those should be p!mp slapped |
Bronze Member Username: SmallvilleSandy, Utah Utah Post Number: 30 Registered: Aug-05 | then whats a good brand that you would recomend? |
Gold Member Username: IlluminatorPost Number: 1462 Registered: Apr-05 |
Smashing? Yes, they're great for that! |
Bronze Member Username: SmallvilleSandy, Utah Utah Post Number: 31 Registered: Aug-05 | then whats another good brand that you would recomend? |
Bronze Member Username: RedrazorFort Walton Beach, Fl USA Post Number: 38 Registered: Jun-05 | But it's Pyle! They make Pyle Drivers. You can litteraly perform wrestling moves with them. Get em' you'll lay the smack down on people. |
Bronze Member Username: RedrazorFort Walton Beach, Fl USA Post Number: 39 Registered: Jun-05 | Seriously though if you want something cheap just get this http://cgi.ebay.com/12-SUB-SUBWOOFER-SUBWOOFERS-WOOFER-WOOFERS-CAR-AUDIO_W0QQite mZ5798586959QQcategoryZ18803QQrdZ1QQcmdZViewItem It probably won't be that much worse than the pyle ;). |
Bronze Member Username: RedrazorFort Walton Beach, Fl USA Post Number: 40 Registered: Jun-05 | I doubt I should be talking though. Those pyles are probably better than what's been in my car for the past month. |
Anonymous | Well let's give him suggestions instead of bashing poor fellar. Do it right the "First" time. Get quality, because over time, you'll get into Audio more and more, and eventually want better and better. Figure out your budget first, because I dont want you buying junk bro. |
Gold Member Username: IlluminatorPost Number: 1464 Registered: Apr-05 | http://p079.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=48.topic |
