Port placement
Username: Bigred2069
Post Number: 91
where should ports go? on the outsides of the box or in the middle?
Username: Quickshot
Post Number: 9
i dont think it matters although youll have a hrad time placing a port in the middle since it will collide right with the subwoofer itself
Username: Basshead86
Ocala, FL USA
Post Number: 277
unless you put the sub on one side of the box and the port on the other like my box
Ocala, FL USA
Post Number: 278
well i suppose that's still on the outside isn't it? i'm an id!ot!! lol
Post Number: 93
well i am going to have 2 12 sry i didnt say.....should they be between the subs or on the outsides?
Ocala, FL USA
Post Number: 279
definitely on the outsides
astrosafari
jl audio makes there ports in the middle of the subs
Ocala, FL USA
Post Number: 281
which is going to take longer to drain, a tub with the drain right under the faucet, or up in the tub where the water takes a while to fill up to?
it's the same concept with a box and its port, the longer the sound waves are in the box resonating, the louder they will be when they come out of the port:-)
Ocala, FL USA
Post Number: 282
which means the farther away from the sub the port is the louder the bass, generally
Username: Cnafets
Post Number: 43
JL has both in their subs in different chambers, that's why the ports seems like its in the middle.
Ocala, FL USA
Post Number: 283
that's probably why they are in the middle lol
astrosafari
does carpeting the box effect the sound? some people were taqlkin a bout a frend of mine and sed that it would sound better with carpet i dont think so and they were sayin he couldnt take the few extra dollars to carpet it and make it better. if carpet makes it sound better im gonna put thick house floor carpeting on my boxes.
Ocala, FL USA
Post Number: 287
NO!! it just matches my trunk!! lol
Ocala, FL USA
Post Number: 288
and good luck tryin to wrap your box in house carpet!!:-( lol
Ocala, FL USA
Post Number: 290
it is just used for an aesthetic look(which means to make it look good)
Post Number: 95
ooh gotcah gotcha, thanks a ton guys
Ocala, FL USA
Post Number: 292
not a problem:-)
