The works
astrosafari
i have a '92 safari and i am going to put a few small tv's, 3 15's, cd and dvd players, ps2/xbox, neons and interior light all around, i will need another battery but how will i recharge the batteries b/c i already have a short sumwhere that is killing the battery i have, i might find it during istallatins of the goods and will i need another altinator after i find the short? i plan on getting new subs as well does ne 1 know of a good sub that are less then $200 b/c i have three and 3 new subs at 200 is a little over my price range for subs and including the rest of the things i want to get.
Username: Taylor17
Kopperl, Texas
Post Number: 2738
If you can't spend over $200, but you're going with 3 15's... Why? Go with 1/2 higher end brands... like Eclipse TI's. You'll get better results going with something high quality, and fewer subs, then you would with more, but lower quality.
Anyway, Kicker CVR's are a good cheaper alternative, also Alpine type R's.
With all that electrical stuff in you're car... not including amp/amps, you'll deffanently need an HO alternator.
