Is 650 RMS to a JL 10W7 too much?
Would 650rms be too much for this sub?
Username: Rob315
Cuse, NY U.S.
Post Number: 570
not even going to answer this
Username: Secretsoundz
St. Paul, Mn USA
Post Number: 8
The dude at the install shop recommended that I get an amp with RMS in the top third of my amp RMS. Like a 500 rms sub getting 350-500 rms.
I'm curious about your question too, the salesman was just recommending what was safe, I dont think a 1000 max sub would die from 650 watts.
Username: Sploosh56
Ohio
Post Number: 799
as long as that power was clean and you didn't romp on that sub to hard and have it in an enclosure it wasn't designed for I think you'd be alright.
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 617
that sub will be fine with 650 rms.. if anything u will just have more headroom with ur amp.. turn the gains down a little bit if u dont want that much power going to it
