New member Username: Subaruwrx163Valley stream, Valley sttream Us Post Number: 6 Registered: Aug-05 | i have about 800$ to spend on subs amps wireing and a capacator. i get deals at circut city, so if possible cound somebody build me a system based on the products on their web site. www.circitcity.com thank you |
Silver Member Username: Dominirica012Charlotte, North Carolina US Post Number: 656 Registered: May-05 | personally if i was you i would buy all my stuff from ebay but since you say that you get deals then go with either some Kicker CVRs or Infinity (prefebly Kappa/perfect although i dont see them on the website) subwoofers and for an amplifier get either a Kicker or MTX amp that does anywere from 600-900 rms you dont need a capacitor those are basically useless...again i would ebay it but apparently you have some nice hookup in circuit city |
Silver Member Username: Mikechec9Chicago/atlanta Post Number: 666 Registered: May-05 | skip circuit city. the discount wont be worth the inadequacies of the products. hit the net. you'll do much better for 8small. i do respect the infinitis though. you can still outdo them on the net. |
New member Username: Subaruwrx163Valley stream, Valley sttream Us Post Number: 7 Registered: Aug-05 | i think im goin to say wit circit city because i am gettin 55% off all items. BUt i have a quwtion when you say an amp wit 600-900rms is that on one sub or the 2 subs added together? |
Bronze Member Username: Basshead86Ocala, FL USA Post Number: 72 Registered: Aug-05 | on the 2 subs more than likely if you are only spending $800 |
Bronze Member Username: Basshead86Ocala, FL USA Post Number: 73 Registered: Aug-05 | otherwise those would have to be some nice subs, and you would have to get them at cost |
New member Username: Subaruwrx163Valley stream, Valley sttream Us Post Number: 8 Registered: Aug-05 | no im talkin about the amp would i have to get an amp rated at 600rms or an amp rated at like 300rms |
Silver Member Username: Dominirica012Charlotte, North Carolina US Post Number: 666 Registered: May-05 | i meant from about 600-900 rms for both subs combined...so from 300-450 rms per sub depending on the amp and wiring options |
Bronze Member Username: Basshead86Ocala, FL USA Post Number: 77 Registered: Aug-05 | i'm sayin you wouldn't put 900 rms on each sub b/c they would have to be meaty subs, and you cant get 2 meaty subs, and 1,800 watts rms worth of amplifiers for $800 |
New member Username: Subaruwrx163Valley stream, Valley sttream Us Post Number: 9 Registered: Aug-05 | so your saying that i have to get an amp thats rated at 300-400 watts rms at 2 ohms |
Silver Member Username: Dominirica012Charlotte, North Carolina US Post Number: 686 Registered: May-05 | these are basically your options if your going to get 2 SVC 4ohm subs(basically the average configuration) 600-900rms @ 2ohms X 1 (mono amp) 300-450rms @ 4ohms X 2 (2-channel amp) |
New member Username: Subaruwrx163Valley stream, Valley sttream Us Post Number: 10 Registered: Aug-05 | if its not too much trouble could you give me a list of amps in the price range of about 400$ that will work with the two 12' kicker comp |
