Amp question
Username: Kicker
Slave lake, Alberta Canada
Post Number: 128
i know this is not the amp thread but can you hook up one remote wire to all your amps of one lead thanks for the help
Username: Ffxdevilarms
Dubuque, Iowa United States
Post Number: 831
yes, just hook it up as if you have to hook up multiple subs to a mono amp. Take the remote from the HU to the first amp then take a peice of remote wire and connect it from the remote on the first amp to the other amps that you have.
Username: Kicker
Post Number: 129
one more question do you need a cross over if your deck and amp have one?
Username: Kicker
Post Number: 130
that is what i did just was not sure if right or not thanks Chris Klein
Username: Tbolt
Collipark, GA
Post Number: 409
Splice or solder the four wires into 1 wire and connect it to the hu.
