Klipsch B-2 good rear speakers?
Username: Krazymofo24
Dallas, Texas
I'm buying speakers one piece at a time. I bought the B-2's for my Fronts until I get the B-3's the matching surrounds are the Klipsch's S-2's will the B-2's work good as surrounds or will I need the S-2's?
Username: Devils_advocate
Post Number: 170
The B-2's will probably be adequate for the purpose.
Post Number: 171
Also, have you considered getting 5 B-2's all around?
Dallas, Texas
Would the B-2 sound good as a center? I would rather do that sure would save me money.
B-3's, B-2's, and C-2= atleast $750.
5 B-2's = Around $500
I think i'll try that the B-2's sound so much better than the Bose 161's I bought first.
Post Number: 172
So long as you keep it vertical and the tweeter at or pointed to ear level, the B-2 will perform very well as a center speaker.
The bonus of this configuration is that the system will integrate much better as the speakers will all voice/timbre match one another.
