Building my first box, a few questions
Box Question
Here is what i am wondering. Right now i have a generic sealed box for my alpine type R subwoofer. 2005 model SWR-1242D. I want to build a ported enclosure for it because i heard they sound so much better in a proper ported enclosure. They are crap in sealed. Now..they sound ok to me..but i would think they could get ALOT louder given the proper tuning/dimensions and all that. Now what i need is a program or some designs that would layout what materials i would need, how to make the port, what to make the port out of. etc etc etc. If anyone has any links to any programs out there it would be a great help. This is my first box that i am building, so i want to do it right.
Im also going to be driving it with 850 watts. Slightly more than reccomended..but i hear they can handle it without a problem.
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 598
a guy was on here before running it with 800 and blew his so be careful.. also your powerhandling will go down a bit with a ported box..the subs will definately gain some spl though..as for programs most us WinIsd its pretty good, u will have to play with it a bit to figure it out though OR read down
Optimum vented box (according to alpine) is
EXTERNAL box dimensions using 3/4' mdf :
18" x 13.5"H x 16.5"
Gross internal volume = 1.7 ft©o.
Vent Area/ (Dimensions) = 15©÷/ (12" x 1.25")
Vent length = 22.75"
Vent Displacement = 0.305 ft©o
Net Internal Volume = 1.3 ft©o
F©o,Ripple,Fi = 33 hz, 2.5db, 36hz
u can use this box and im sure it will perform pretty good.. it might be a little tough since your going right into a ported box as your first.. ur gonna want to get some 3/4 MDF medium density fibreboard from home depot or something.. u will need a jigsaw- works the best IMO since u can cut holes for the sub with it to ... your basic tools , Level or strait edge, framing square, Clamps And or screw gun to hold the pieces together while the glue dries(remember to pre drill holes so the wood doesnt crack) I also recommend 90¢ Clamps.. holds the pieces square , some good cabinet glue, (somebody feel free to add anything if i forgot). as for making the port.. it will be a "slot port" which simply means it is build into the box using Mdf (looks like a slot)... u gotta make sure when making a slot port to glue the right pieces on first.. leave the top off so you can put your slot pieces on... you will notice the slot length is longer than any of the box sides..so what u have to do is turn the vent around a corner of it.. how u measure it is using the centerline of the port.. and finally , IF u have to go out and buy a ton of tools to build a box id just get a shop to do it for you unless u plan on making a hobby of it.
Username: Rzarector
Post Number: 599
wow wtf.. those F'ed up signs on the box spec where suppose to be a small 3 for Cu ft
Corr: F3,Ripple,Fb = 33 hz, 2.5db, 36hz
and the messed up sign on the 90 was suppose to be a degree sign,. thats the last time i use character map lol
Username: Liquid_slap
Westland, MI
You can go here to find out what tools you need and stuff.
http://www.crutchfieldadvisor.com/S-Na4JSqsTXvw/reviews/20030701/build_box.html
Westland, MI
Go here for port calculations.
http://www.carstereo.com/help/Articles.cfm?id=31
Box Question
Awesome! Thanks for your help. Right now i have the gains set a little below what my preouts on my head unit are, once i go to vented i will most likely drop it down to 3 volts on the amp. the preouts are 2 volts on the head unit.
Username: Rzarector
Post Number: 603
let me know how it goes.. and do not use those port calculators.. they are inaccurate.. its better to use a proper program
