NBest 18" sub around for 750-2000 rms
I want big and loud but also nice lookin so if you can help me out I would appreciate it. and Affordable $-800.
Username: 54danny54
Post Number: 888
RE XXX www.reaudio.com
u can get a certain model of DD audio for that price..a 17 inch i think www.ddaudio.com
Username: Tbolt
Collipark, GA
Post Number: 329
Eclipse TI pro. www.eclipse-web.com/sw9100/sw9182pro.html
You may have to search around for a price under 800.
Username: 02gsxr
Post Number: 71
I will also put in a vote for the Eclipse Ti Pro! That's really an amazing sub!!
Depending on what you are looking for, I would also check out TC Sound's custom CF sub. It uses an Eclipse Ti Pro frame, but just about everything else is different. It has a custom carbon fiber cone, and a revolutionary motor/VC design. The new design allows extreme Xmax specs without the usual distortion that has always been a limiting factor. The sub is rated at 6kw RMS but can easily take 8k. It uses quad 1ohm coils and has a sensitivity rating of 108db 1w/1m. Best of all, 4" XMAX!! They were origonally like $2,000, but you can sometimes find them for like $500 used. There were only 28 of these ever made!
Username: Shackashacka
Post Number: 87
lol, i dont think the TC Sounds CF sub is what he's looking for
its about 4,000 watts above what he wanted and its a pain to find them too
i'd stick with the Eclipse Ti Pro
Username: Riebread77
Post Number: 504
where can you find it for $500 used?
muddywaters
Treo SSX 15" 2,500 watts rms power handling
