Hifonic amps any good?
Username: Hurleyblink
Post Number: 142
was wondering if hifonics makes a okay amp, like the zx1000 or the class d amps that supposively push out 1000 w rms @ 1ohm
Post Number: 144
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 28
ok, but you might want to save a little more and get something better.
Username: Subzer0
Richmond, KY USA
Post Number: 515
they are fine for the budget, a lot of people use them..
Although a pinch overrated, i'd rather have a brutus then any other sub.. I trust them.. a lot.
Username: Iowahawks19
Post Number: 382
if you do go HIFONICS, go with the brutus line, but personally i was about to get one, and glad i didn't(friend got one) his system isn't all that clear and it's basically the same one as mine with different amps
look somewhere else if you have the $
Username: Rovin
Trinidad & T...
Post Number: 90
Everyweek that question is asked (that's Y no1 is answering) & the response is they are overated but arguments are some ppl love em & some hate em .
The usual answer is the lowest brand name u should get is MTX or a step up JBL .
Username: Subzer0
Richmond, KY USA
Post Number: 517
then any other amp* sorry i'm not with it tonight lol.
Username: Xdrummer03
Tenessee
Post Number: 98
Yes and Hifonics amp are very reliable.
Post Number: 146
alright, i have 2 kicker cvr's dual 4 ohm, i can hook these up to get a 1 ohm load correct, also will the bx1000d get very hot under this kind of load (if anyone has/runs 1 in this config
