Silver Member Username: Iufan4lifeulLouisville, Kentucky Post Number: 300 Registered: May-05 | Dynamat xtreme trunk kit http://cgi.ebay.com/BRAND-NEW-DYNAMAT-XTREME-TRUNK-KIT-20-SQ-FT-19405_W0QQitemZ5 794977939QQcategoryZ1498QQssPageNameZWDVWQQrdZ1QQcmdZViewItem $80 (includes S&H) Is that a good deal? Or could I just get buy buying some dynamat just for the trunk lid? That is where most of my rattling is coming from... |
Bronze Member Username: AcevolkovSpringfield, Missouri United Stated Post Number: 61 Registered: Jul-05 | ive heard that the dynamat trunk kit wont complety cover all of the trunk for larger cars. i would go with edead, its alot cheaper and can be bought in bulk, the way i like it. |
Silver Member Username: Addicted2bassMiami, Florida USA Post Number: 967 Registered: Nov-04 | i'd go secondskin soudn deadener, |
Silver Member Username: Supraspyder420Sammamish, Wa U.S. Post Number: 111 Registered: Jul-05 | I used that kit on my friends integra and it covered the hatch top, full back wall and a few large peices over the fender's and outer body panels. It sounded awesome but it would need alot more to do the whole thing. ID get like 100SQft of edead or second skin to do the whole car. but if your doing it for rattling only then yeah thats enough |
Silver Member Username: Big_osoPost Number: 231 Registered: Jun-05 | second skin pwnes |
Silver Member Username: Riebread77Post Number: 483 Registered: Jun-05 | 100^2 ft takes a lot of work to lay down...and getting edead or imitaters, they don't have as good adhesives or are as thick as dynamat...if you want the best with easiest application...juss get a bulk pack of dynamat xtreme for $125 shipped off ebay...it'll cover the entire trunk and then some. |
Silver Member Username: Big_osoPost Number: 232 Registered: Jun-05 | Hmm doubt it. Second Skins product line has the highest heat tolerance and is 60 mils thick. And you can buy it for a fraction of the cost of dynamat. If you live in a very warm climate you risk the dynamat adhesive giving way and eventually losing bond. |
Silver Member Username: Big_osoPost Number: 233 Registered: Jun-05 | Once again Second Skind PWNES |
Silver Member Username: FfxdevilarmsDubuque, Iowa United States Post Number: 771 Registered: Jul-04 | Ryan, are you on something??? Edead is some of the thickest you can buy, if not the thickest there is. As far as adhesives, edead sticks extremely well. At the price you cannot go wrong with Edead. Dynamat is a rip-off in mine and many others opinion. |
Silver Member Username: LettoMilwaukee, WI Post Number: 135 Registered: Jun-05 | Dynamat was first and is proven. They can pretty much charge what they want. When people think of deadeners, the 1st thing that comes to mind is dynamat. The others have to charge less in order to compete and get their name out there. Personally I like Dynamat better than Edead... but haven't seen/tried second skin. |
Silver Member Username: FfxdevilarmsDubuque, Iowa United States Post Number: 783 Registered: Jul-04 | So just because something is first that makes them the best now??? I wonder why every year there are updates to pretty much EVERYTHING in the world today. |
Silver Member Username: Riebread77Post Number: 495 Registered: Jun-05 | guys...you must be smoking...dynamat xtreme requires no heat gun at any temp...edead requires it under 50 degrees and almost any other imitater requires a heat gun for application...think of it this way...would you want go with a company that ONLY makes dampener or one thing at all (i.e. optima batteries)...or a company that specializes in everything...dynamat stays in business by ONLY selling dynamat and nothing else...i think they are proven...dynamat xtreme will never lose its adhesiveness, where others do...especially upside down...trust me on that...i've used extreme, the spray, and imitaters...the imitaters give you more for less money, but doesn't work as good, doesn't stick as good, and takes a lot more time to install...if you have $125 to spend...get a bulk pack of dynamt xtreme on ebay...you'll thank me later |
Silver Member Username: FfxdevilarmsDubuque, Iowa United States Post Number: 786 Registered: Jul-04 | People like you are the reason why people overspend. I have used edead and i installed it in winter around 40-45 degrees and i put it on my trunk lid. I have had NO issues with it falling down or not sticking. I also did not use a heat gun, nor did it take very long to install. 125 dollars can get 125 square feet of the regular edead or 83 square feet of the best mat edead. The only reason why they are in business is because the charge so much and were "the first" so people just think they are the best. |
Silver Member Username: Riebread77Post Number: 496 Registered: Jun-05 | takes lots of time to install 125 square feet in a car man...not everyone has that kind of time...most people here are full time students and have jobs on top of that...edead is a better value...but if you have money to spend...go with the best (dynamat xtreme)...chris, do the test challenge yourself...take a piece of your left over edead...buy a little piece of dynamat xtreme...and you will actually see and feel the difference, it will amaze you |
Silver Member Username: FfxdevilarmsDubuque, Iowa United States Post Number: 787 Registered: Jul-04 | I never said you had to install that much, i just said for that much money you could get that much. Or you could get more edead then dynamat for a lower price. All i am saying is that using dynamat is unnecessary. It is all basically the same stuff anyway, that is why i think it is pointless to spend the extra money. |
Silver Member Username: Supraspyder420Sammamish, Wa U.S. Post Number: 112 Registered: Jul-05 | OK i know that OSo swears by second skin and so do alot of other people, but is it alot better than dynamat, edead,cascade, and some other mats? Its 65mils while dnynamat is 44mils i think. now although seeming like it would be better (b/c of thickness) is the material less offective? basicly what im asking is, money aside, are other companies making better mats then dynamat? or is it lik nike, your buying a brand name? |
Silver Member Username: FfxdevilarmsDubuque, Iowa United States Post Number: 788 Registered: Jul-04 | Edead v. 1 SE studio Edition is 70mils thick and it is $1.50 per square foot. |
Silver Member Username: Big_osoPost Number: 234 Registered: Jun-05 | Second Skin PWNES all the other deadners. If you bothered to do your research not all deadners require a heat gun. Second Skind products have the highest heat tolerance and their product is 60 mils thick. So you go ahead and be a dumba$$ and order dynamat and i gaurantee my car will be a lot quieter than yours with all your high dollar dynamat. BTW SS spectrum sludge is the best product on the market for doing the interior floor. SECOND SKIN PWNES |
Gold Member Username: Jonathan_fGA USA Post Number: 4360 Registered: May-04 | Lizardskin ceramic spray . Credit card thin, 10-12db sound reduction, and keeps your interior a good bit cooler. You can also sand it and paint it, and being a spray it gets places like inside door panels. Of course, you can layer your favorite rubberized sound deadener on top of it to help even more. That being said, of those listed above, I'd choose Second Skin Damplifier Pro. |
Silver Member Username: TboltCollipark, GA Post Number: 313 Registered: Dec-04 | Second skin hoar lol jk. |
Silver Member Username: Big_osoPost Number: 235 Registered: Jun-05 | told you second skin pwnes |
Silver Member Username: FfxdevilarmsDubuque, Iowa United States Post Number: 790 Registered: Jul-04 | why cant you say ownes??? |
Silver Member Username: Big_osoPost Number: 239 Registered: Jun-05 | i can but if you have to ask why i say pwnes then you wouldn't understand |
Silver Member Username: LettoMilwaukee, WI Post Number: 137 Registered: Jun-05 | Hmm... pwned was popular in the TFC gaming world like 6ish years ago... Probably even older in some others... You're probably one of the CS wh0res that doesn't keep up with the sayings... |
Silver Member Username: FfxdevilarmsDubuque, Iowa United States Post Number: 791 Registered: Jul-04 | TFC gaming CS??? |
Silver Member Username: FfxdevilarmsDubuque, Iowa United States Post Number: 792 Registered: Jul-04 | I looked of pwned, so nevermind on that. TFC is Team Fortress Classic im guessing, and CS is Counter Strike. Am i right??? LoL |
Silver Member Username: LettoMilwaukee, WI Post Number: 150 Registered: Jun-05 | Yes, you are right sir. |
