Anyone to check for Port Noise on WinISD
Username: Shackashacka
Post Number: 84
Is thdre any way to check for port noise on WinISD? or any formula's i could get to help me?
i have 2 12" V-Max's and ive had port noise already on my first box(i think...it sounds lke a flapping noise almost), and i dont want a repeat of that
i had small ports though...1.5" i think
kinda small, but thats all i had
now i have a bigger trunk
should i go slot or PVC ports?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 579
whatever works.. to check for port noise go to front velocity and make sure it is under 25 m/s
Username: Addicted2bass
Miami, Florida USA
Post Number: 977
i think its whatever is under 15m/s i could be wrong though
Username: 02gsxr
Post Number: 63
17m/s is the actual velocity you should stay under...
