This girlie needs help re: the Pansat 2500A
Username: Lez
Toronto, Ontario Canada
Hey guys,
I've read most posts concerning the Pansat 2500A, and still haven't been able to figure out what's wrong. But I know absolutely nothing about satellites, recievers and such, so I could've stumbled across a solution and not known it. Anyway, when I check the signal strength, for most satellites the "Level" is between 75-90%, but absolutely nothing appears on the "Quality" bar, and of course, no channels appear. That's about it. Help is very much appreciated.
newer
goto dsscentral.nett
go to file archives,
go to fta files
quality
turn your dish a little bit
BoogyMan
DO a scan? channel won't just appear b'coz you found the satellite.
Username: Lez
I used to turn the dish before when this happened, but it no longer works. Same goes for scanning.
Thrill 1951
-"SHOW" Us all your girlie
and we will show U
all our dickeeeeeees
Thrill1951
I think you just showed us you are a Dick! Now go play with yourself and grow up! What a bunch of immature retards there are here at this site!!!Why doesn't this sites moderators kick these children out???
LK
The mods here are the imposters and making all the stupid posts...this is not your typical DSS forums..these forums are for 2 purposes..monitor Dss activities and any hacks or breakthroughs..bring $$$$ to Ecoustics and their sponsors..the mods here are informants and work for the FCC..
Thanks for your reply LK, and for staying strong and helping us out here with questions! You are one of the only reasons I still visit this site!
harlingen
me too
