Reference vs kappa
Bostitch
Hey, I was just wondering if there is much of a difference between the infin. reference and kappa series if they are not amplified. I am just looking to get a little nicer sound on a budget, thanks
Username: Illuminator
Post Number: 1249
Yes, it has been stated several times that the Kappas will usually sound worse if being powered by the internal amplifier on the headunit.
Username: Riebread77
Post Number: 421
yea there power handling is very high...and not average sensitivity...its not that they sound bad off the headunit...its that they will really come to life with an amp.
Username: Sx3
Illinois USA
Post Number: 173
What's a good amp to use for 2 5.25" Infinity Kappas?
