How to measure clippage with a DMM?
Username: Letto
Milwaukee, WI
Post Number: 120
If I want to tell if my amp is clipping, and I have access to a DMM... would I be able to use it to do that?
Would I just check if it is outputting DC voltage, or how would I go about checking this?
Username: Invain
Michigan United States
Post Number: 3372
You can't measure clipping with a DMM. You need an oscilloscope.
Username: Letto
Milwaukee, WI
Post Number: 125
Glass said this "the tool to look for clipping is called an oscilloscope. you'd also want a DMM that reads true-RMS and has non-inductive leads."
So my guess is he's talking about using both of these together?
Username: Jonathan_f
GA USA
Post Number: 4348
If you want to get a ballpark on setting the gain correctly, a voltmeter can get you close, assuming your amplifier is rated correctly or underrated. Simple power equations, how much power is your amp rated for, at what voltage? After that, you'll need a dummy resistor.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8900
yessir
the DMM can measure AC voltage, but it can't visualize a sine wave to see clipping like the scope can
Username: Letto
Milwaukee, WI
Post Number: 127
It doesn't say how much power at what voltage on the websites specs... just the power at the given impedance.
Per channel Power:
125 W X 2 @ 4 Ohms RMS
250 W X 2 @ 2 Ohms RMS
500 W X 1 @ 4 Ohms Bridged RMS
1500 Watts Peak/Max
Given this information, and given I have access to a DMM, is there any way I can either set the gains properly or be able to tell if they are set improperly?
