MTX Audio Thunder TA92001 V. Rockford Fosgate Power T30001bd
Superoager
I would like to know which of the two is better as far a quality, value, and true RMS power. Also, are their any other amplifiers in this power range I should consider before these two. thanks.
look into orion, and i havent had the chance to hear the MTX amps, but i saw two rockfords like the ones ytour taling about hooke up to a MT 18" and it was LOUD. i think rockford power series might be starting to pull rockford out of the hole they put themselves into over the past 2 years
