Still looking for an amp for my subs...
Username: Pdivvy5
New Port Richey, FL United States
Post Number: 88
Okay, here's the deal. I have two JL Audio 12 inch W0's, which are 8 ohms. I've done a lot of research and still can't find an amp i want to buy. I'm looking for an amp that's around $200, and i don't really have a brand preference. Please help me find the right amp. Thanks.
Username: Kd7nfr
Montpelier, ID United States
Post Number: 586
eBay it man. $200 bucks is pretty low...
Username: Thrushdtd
New York
Post Number: 269
what are the specs for the W0's?
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 628
125 rms...he has to find an amp that is 250rms at 4ohms
Post Number: 629
http://cgi.ebay.com/Brand-New-Kicker-KX250-2-2-CH-250W-AMP_W0QQitemZ5791794533QQ categoryZ48598QQrdZ1QQcmdZViewItem
exactly what you need and those amps are supposed to be underrated so your getting a little bit more than that
Username: 78elcaminoman
Dallas, Texas United States
hay i dont know if this will help but thes sites have some cheap good amps and anything else u want:
http://cardiscountstereos.com/
http://www.a1discountcaraudio.com/
and of corse www.ebay.com, hope i helped sum
Username: Pdivvy5
Post Number: 89
Thanks guys
Username: Pdivvy5
Post Number: 90
I was lookin on sound domain and i found this amp. http://www.cardomain.com/item/KIC04KX25022 It's a refurbished amp, so i was wondering if it's worth taking the chance by buying it. What do you guys think?
Braden N.
Amp for Audiobahn ABB102Q
I just want a cheaper amp that will get the job done and last a while
the dual subs are 600 watts RMS
Username: Iowahawks19
Post Number: 371
braden, start your own post, don't rob someone elses, but since you allready did it, how much $ you got to work with, thats kindof the biggest issue, anyone could give you advice on a amp thats 1200 watts(you might not like the price though)
and btw, audiobahn is overrated, so lets say those subs are about 450-500 watts rms
