New member Username: KaribPost Number: 1 Registered: Aug-05 | The same thing happened to me as to "Newman" on this thread https://www.ecoustics.com/cgi-bin/bbs/discus.pl?pg=prev&topic=4&page=142774 (in June). I can't get my deck to work now. It stays out half-opened and hitting the reset button causes it to go up midway and then reverse to the half-opened position. Disconnecing the car battery proved useless to the cause. The CD won't come out either. Did anyone ever solve this problem without having to replace the deck or head unit or taking the thing apart? This bites. I have to drive to and from work without tunes. HELP PLEASE!!! |
Gold Member Username: IlluminatorPost Number: 1286 Registered: Apr-05 | It really isn't that difficult to repair yourself. The cable can be ordered directly from www.kenwoodparts.com and is fairly easy to install. |
