Problem with Clifford Concept 100
Username: Gump
I'm having problems with my Clifford Concept 100 alarm, whenever I arm it about 3 seconds later it beeps as if the car was tampered with, also the autoarm feature does not work. Can anyone help me out?
Username: Jeremyc
Germany
Post Number: 744
The alarm thinks that the hood or trunk is open. Check both pins, and make sure sure they are properly adjusted, and clean.
