Bronze Member Username: JronPost Number: 18 Registered: Jul-05 | I just installed am mrd-m605 in my car. Im looking at the diagrams for wiring the sub and it seems like they want me to go directly from the amp to the sub, is this correct, i have been out of the game for years and have never wired a sub like this any input is apprectiated. |
Silver Member Username: JaackdethUnited States Post Number: 334 Registered: Sep-04 | Is the sub a DVC or a SVC, and what is the Ohms? |
Bronze Member Username: JronPost Number: 19 Registered: Jul-05 | 4 ohm dual voice coil subwoofer type r |
Silver Member Username: JaackdethUnited States Post Number: 335 Registered: Sep-04 | Go here, and then just look down at the list of what configuration you need. http://www.jlaudio.com/tutorials/wiring/index.html |
Bronze Member Username: JronPost Number: 20 Registered: Jul-05 | yeah i understand parallel and series but its just that ive never wired a speaker straight from the amp to the voice coils of the subwoofer. so my assumption of running the speaker wires directly from the amp to the voice coils of the woofer is correct right? |
Silver Member Username: JaackdethUnited States Post Number: 336 Registered: Sep-04 | Well normally you would run the speaker wires to the enclosure spades from the VC's, I guess I'm not getting what you mean! |
Bronze Member Username: JronPost Number: 21 Registered: Jul-05 | yeah thats what i mean. normally speaker wires to enclosure spades, amp wire to enclosure spades outside basically 2 sets of speaker wire, in this diagram i am seeing it is only one set of speaker wire. |
Bronze Member Username: JronPost Number: 22 Registered: Jul-05 | i just want to be positive that i am correct. |
Silver Member Username: JaackdethUnited States Post Number: 337 Registered: Sep-04 | Yes that is right!!! Sorry about that! It does get confusing when you have all the +'s and -'s to put together to get your right ohms! |
