I've googled it about 20 times different words each time, but cant seem to get a clear answer on how to get into my dash/remove the radio/hook new one up, i've been to some websites that say remove screws around dash but mine have none, and i need to get the radio out
Your gonna need to take the whole front trim panel of the dash off. There's gonna be a few screws, you just gotta look for them. Other than screws there will probably be a few clips holding it on as well. What kind of vehicle do you have?
DANNIIIEEEE
i got it now, thanks Joe, other forums don't even answer to unregistered guests
yea i didn't know how to get the trim off, that was the problem, but i just popped my screwdriver around n waited till somthin clicked
