hello, can the dish 500 with the 2 lnb's connected in one unit with the built in switch, can ever be used for fta?? let me know.
trying to help
you can try.. I used it for a while but was missing few channels.. You just can not use one wire as is used by dish network, u need to have different wire for 110 and 119 and then use a switch on it.. should work..
dish 500 owner it will work but you need to use a dish pro ch. list
