2005 Mustang Problem
Big Bobs Bobs
I'm having a problem with the power wire of my amp in my Mustang. I can't find anywhere to put the wire through. So I decided to drill a hole, but I can't find a place where I can see what I'm going to drill through. Any suggestions?
Username: Iowahawks19
Post Number: 335
drill somewhere else????
Big Bobs Bobs
Where??? I can't see anything. I can't tell where it's going to go through.
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 546
just drill .. if you hit something important it needed to be replaced anyway
Username: Pimpzeus
United States
Post Number: 20
i think drill a hole in the floor and run it to the battery that way. whateveer wire is under the car can be rapped with a weather resistant material u could put silicone around the wire where it goes through the hole
