Unregistered guest | MOFO10 Aluminum Rib Insert Dual 2 ohm Voice coil 2400 Watts power handling 270 oz. magnet 3'' BASV/Kapton hybrid 18 AWG voice coil SPL 89dB sealed box: n/a ported box: 1.75 cu. ft. tuning: 40 Hz port size: 4'' (d) x 11'' (l), 1 port. SPLW10 SPL SPLW10 10 inch Pro 2200 Watt Subwoofer 270 oz. magnet 2200 watts power handling 270 oz. magnet 3" BASV/Kapton hybrid 18 AWG voice coil Dual 1 ohm voice coil Die cast aluminum basket Black wrinkle finish with Diamond cut Cloth laminated paper cone with MD6 coating Black wrinkle finish front & back plate Large foam rubber surround One piece, 360º rubber gasket Dual Conex spider Woven tinsel lead through spider Chrome screw terminals Includes deluxe wood case SPL 89 dB Sealed box: N/A Ported box: 1.65 cu. ft. Tuning: 45 Hz Port size: 3" (dia) x 9.25" (length) Also Available in 12 inch & 15 inch models the web site to see the pictures is: http://www.a1discountcaraudio.com/ just click on 10in subs |
Gold Member Username: SubfanaticKy Post Number: 4614 Registered: Dec-04 | Mofo's are more popular, but i havent heard a SPL sub yet |
78elcaminoman Unregistered guest | i heard that the mofo dont have good sound |
Silver Member Username: Subzer0Richmond, KY USA Post Number: 400 Registered: May-05 | SPL subs are fun.. I used to have a 10" but gave it to my sister for her eclipse.. haven't seen it since but it still bumps around now and then ;). only had 200 watts going to it..too. |
78elcaminoman Unregistered guest | but did you like it, waz it a good sub |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 318 Registered: Jan-05 | the mofo's are spl subs they were made to get loud and thats it. |
Silver Member Username: Subzer0Richmond, KY USA Post Number: 401 Registered: May-05 | and the spls are pretty much the same but in my tiny sealed box.. it seemed to flow with the music when it was underpowered.. nicely and had a good thump.. enough to rattle my lisc. Plate. |
78elcaminoman Unregistered guest | do you know of any that artent that expencive that puts out serious bass and sound. they have to be 10s im limited on space |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 320 Registered: Jan-05 | is $239 too expensive that would get a re audio sx they will have plenty of spl and still sound good. |
78elcaminoman Unregistered guest | sure thats a good price, or could i get like a sub with spl and another sub that is for sound, one 4 bass and one for sound and 2 different amps |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 321 Registered: Jan-05 | ya you could but i wouldn't recommend it because the subs won't "blend" together, it will sound awful cause 1 sub might sound different than another sub, but its up to you. if it was me i would just get the sx it has plenty of spl and a lot of ppl like the sound quality it has. |
78elcaminoman Unregistered guest | ok thanks 4 the advice |
