Sub Help!!!!!!!
Username: Jaackdeth
United States
Post Number: 261
Wow! after reading all these threads and doing my searching over the past few weeks, I just plain need help here lol
OK, I have asked before, and I got some good info, but I don't want to make a big $ mistake either. I have a 90 caddy, and my sub box has to go in the trunk. I am thinking I want to go for SQL, I need to be heard!!!
After several attemps on subs, I'm not getting there, and then I read where alot of people are using (1) sub, and I'm using 2 12's.. What is better, (1) good sub? what size? or 2 or more not as good? Don't know if that makes any sense, but can I be heard, I mean HEARD with only (1) sub in the trunk, and what would that sub be and size. And can someone give some brands, and boxes or box for it, or them to go in. I'm not rich, but lets say I'm just looking. Thanks!
Username: Scubasteve
Annapolis, MD
Post Number: 241
With subwoofers, or any speaker for that matter, what counts is volume. The greater the volume of air you can move with your speakers, the louder it will be. To get volume, you need to things: cone surface area and excursion. Excursion refers to how far in or out the cone can move when electrical current is passed though its voice coils. So, to recap, if you get a sub with more surface area (a 15" or 18") it will be a lot easier to move more air. Your other option is to get subwoofers with greater excursion, or you can just get more subs. Boxes are also an important consideration. Certain ported box designs can make a 6.5" speaker sound as loud as a 12" speaker. Whether you decide to go with more subs, bigger subs, or subs with greater excursion, its important to remember you'll need more power.
Username: Jaackdeth
United States
Post Number: 263
Whats confusing is what to go with! I have 2 12" PPI subs in there now, and in a pre-fab ported box. The problem around my area is there is no real audio shop close by, and most of my things are purchased online. Can you or someone recommend some set-ups that might work well in a trunk! Thanks
Annapolis, MD
Post Number: 244
Can't help you there, i'm not the one to ask about SPL setups.
Username: Jaackdeth
United States
Post Number: 264
Ok SS, thanks for your help....!
Anyone else??
Username: Taylor17
Kopperl, Texas
Post Number: 2674
SQl? I need some kind of price range. I can give some suggestions on $100 subs, or $1000 sub. Same with amps. As you prob already know, like with most things, you get what you pay for.
Username: Jaackdeth
United States
Post Number: 265
SQ and SPL, well depending on whats out there, or whether I can go with 1 sub, say 4-500 on the subs, and the amp I can take care of!!! Just let me know that I can go to 1 ohm! Thanks for all your guys help!
Username: Taylor17
Kopperl, Texas
Post Number: 2676
Sounds like a good job for the RE x.x.x I think the 12 is around $420, and its 1600 watts rms, so you'll need a pretty big amp. It should do the job though.
A good cheaper amp would be the MTX 1501D
Username: Jaackdeth
United States
Post Number: 267
Where can you get a RE? And thanks btw
Username: Jaackdeth
United States
Post Number: 268
Would you be talking about something like this??
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5792038543&category=18804 %26%26
Username: Legacyaudio
Post Number: 70
lol no
go to reaudio.com then go to their contact-- you will want to buy the RE 12 X.X.x just call the number and their people will get everything handled---DONT BUY THAT SUB-- taylor said 420$ not 120$
Username: Jaackdeth
United States
Post Number: 270
LOL, no I wasn't going to, just haven't heard of RE to much, ok will do that. Any idea what kind of box I would need for 1 12" this is going in the trunk of a caddy, so it's going to have to pound, I have 2 12" right now that don't do sh!t~
Username: Jaackdeth
United States
Post Number: 272
Anyone know what enclosure would be good for a 12" RE?
Username: Taylor17
Kopperl, Texas
Post Number: 2679
The link didn't work for me, but if its $120, I'd be willing to bet its not the same thing.
The 12 is $405, and there is a $25 charge to change the voice coils to quad, or any other configuration.
As far as the box, if you really want this sub to move a sh1t load of air, go ported, and tune 28/30HZ.
www.reaudio.com These are the subs Glass uses if that gives you any confidence.:-)
Username: Jaackdeth
United States
Post Number: 275
Forget that link, that was something else LOL.
Ok, Thanks for this link, do you think though that one of these 12's can outdue 2 12's? I have those PPI DCX 12's!
Also I am sooooo new to boxes, can you find these made already, or do you have to build them. Thanks I appreciate it.
Username: 54danny54
Post Number: 741
jack...u willin 2 sell 1 of ya ppi's out of box?
Annapolis, MD
Post Number: 263
no, that link is not something else. Thats RE equiptment, the sellers call it an HC, but I believe is an SE, unless they made a model called the "HC" that I'm not aware of. $120 is not the price for it, its just the current bid. I'm not saying you should but it off ebay, but thats an RE.
Username: Taylor17
Kopperl, Texas
Post Number: 2684
I'nm not sure if you can buy a ported box off the net, building one would be the best way.
Unless you want to buy an SS box? I think there pretty expencive, but suposed to make you're sub sound really good.
Username: Jaackdeth
United States
Post Number: 276
Compluva, you can have them both for $175+ shipping, I don't have the original boxes anymore, but I don't need just one.
Scuba, yea I meant that, I knew it was a RE, just not a xxx, I don't know how I got that fixed up.
Taylor, What is a SS box?
Username: Jaackdeth
United States
Post Number: 279
bump
Annapolis, MD
Post Number: 269
Jack, I believe he's talking about an enclosure design known as a "snail shell" such as those sold by http://www.powered4sound.com/
You might want to give them a call if your not up to building a box yourself, their results are pretty impressive from what I've seen on their website and from what people say. They'll build a box for any sub.
Username: Jaackdeth
United States
Post Number: 280
Scuba, oh ok, seen someone talk about one of those in another thread. Thanks for the info, I will do that, call and get a price list. I never built one before, and don't have the proper tools to do it with. Appreciate your time.
Compluva, did you see what I posted??
Username: Jaackdeth
United States
Post Number: 283
Just got a look at that enclosure, they want 400 for that. Any other ideas?
Annapolis, MD
Post Number: 272
damn, thats a bit pricey. The sub is a XXX right? I could build you a ported box to the RE specs if you wanted but it would be pretty pricey to ship, I've never shipped one of my boxes before. Also, I'm about to go on vacation then back to college so I don't know if i'll have enough time. Where do you live though?
