Hypothetical
Username: Halby
Parsippany, NJ
Post Number: 61
This question is really just something I was thinking about the other day so feel free to answer it if you feel like it...if not no big deal.
If you had a good quality DVC sub(you pick the brand) and decided to run a seperate amp to each voice coil, what would the effects be of:
1) Sending unequal amounts of power to each coil, from let's say two good quality but just different sized amps.
2) Using one amp sending clean power and then another amp powering the other coil with poor quality.
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 586
i was told that an uneven wattage between 2 voice coils would damage the sub over time
Username: Illuminator
Post Number: 1160
Yeah, the coils are bound together, if they're moving individually to each other, they'll seperate and damage the sub. You could possibly get away with it if you were using two of the same model amps with the same output(mono) going into the sub, but I don't recommend it.
Username: Gpz1100
Post Number: 18
In addition to what's already been said, even when hooking it up to the same amp, ideally you want to drive both VC's with the same signal.
My alpine amp puts out the same power to a 2 ohm load as it does to a 4 ohm bridged mode -- that is, 2 x 250 (2 ohm) or 1 x 500 ( 4 ohm).
Given that, by running in bridged mode, you are ensuring both vc's receive exactly the same signal (including phase).
Good question.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8553
one: damaged sub
two: damaged sub
Username: Carguy
Post Number: 3700
three: money wasted.
Username: Halby
Parsippany, NJ
Post Number: 64
Yea thats what I figured...I am not in that situation, just curious. That's why my friends call me whiskers, b/c I'm curious like a cat.
Username: Halby
Parsippany, NJ
Post Number: 65
Sorry, a little Harry Carrey ala Will Ferrel thrown in there.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8560
harry carrey.. that's like hari kiri, only.. not Romanji, and not japanese..
lol
anyway, different power levels = coils fighting each other. results in fried sub
poor quality equates to clipping, which equals distortion. distortion also fries voice coils.
