Bronze Member Username: SoundideasPost Number: 14 Registered: Jul-05 | How many here feel that bi-wiring makes your speakers sound better? |
Silver Member Username: T_bomb25Dayton, Ohio United States Post Number: 359 Registered: Jun-05 | A good design it will I would rather have single wiring though some companies like Dynaudio,Sonus Faber,Vienna Accoustics dont beleive in biwiring{Franco Serblin} Sonous Faber doesnt believe in biwiring he says you should not split the crossover in half.But lots of people have their own theories,If its designed right it will be a difference in sound if you biwire. |
Silver Member Username: DiabloFylde Coast, England Post Number: 171 Registered: Dec-04 | I've tried it and found no significant advantage - or disadvantage. When I initially biwired, I thought it sounded a lot better (clearer mid-range). But I then compared it blind and couldn't tell the difference. If you spend time and money making a change of any sort, then you want (or demand) that it sounds better. I'm not saying that it will never make a difference. There is some analysis here - http://www.pcavtech.com/techtalk/biwire/ which shows that "Biwiring has no electrical effect if the speaker wire is properly designed for the speaker and the length of the wire, and the wire has lower series impedance than the source impedance of the power amp - both these conditions are commonly satisfied." (my emphasis). Speaker manufacturers can have different views, e.g. http://www.legendspeakers.com.au/information/biwiring.html http://www.coincidentspeaker.com/whatsnew.html#Anchor-Wh-20834 Try doing a search on this board for hundreds of other opinions. diablo |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 1290 Registered: Feb-05 | If your speakers are designed with biwiring in mind it does make a difference. It makes a difference with my Paradigm Studio 40's. There is a small improvement in coherence. |
Silver Member Username: Joe_cOakwood, Ga Post Number: 726 Registered: Mar-05 | I do suggest removing the jumper bars you get with bost bi-wirable speakers though. Replace it with jumpers made of the same wire your using. Also I would try connecting the wires from the amp diagonally instead of buying twice the wire. |
Gold Member Username: Paul_ohstbucksPost Number: 1643 Registered: Jan-05 | How about tri-wiring?? If two pair is better, WOW....I bet three would be really great!! |
Silver Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 992 Registered: Feb-04 | If your speakers are designed with biwiring in mind it does make a difference. Hard to tell if they are, since it is also a marketing gimmick for some speakers. |
New member Username: Mr_biasPost Number: 2 Registered: Jul-05 | I enjoy the Audio Critic, an online (previously in print) publication that uses scientific and quantifiable measurements to test audio equipment, along with a healthy dose of double-blind tests. Here's their take on Biwiring, along with other "Top 10 Audio Lies..." This might be opening a can of worms, but #7 covers Biwiring concisely. http://www.theaudiocritic.com/downloads/article_1.pdf |
Silver Member Username: Joe_cOakwood, Ga Post Number: 743 Registered: Mar-05 | I agree with that article, I really don't hear any difference at all, but I did with removing those gold jumper bars. |
Silver Member Username: Black_mathPost Number: 263 Registered: Dec-03 | What do you call liars when they are lying about what the lies may be? |
Silver Member Username: Joe_cOakwood, Ga Post Number: 749 Registered: Mar-05 | politicians? |
