2 4" type S or 1 5X7 Type S?
Username: Supraspyder420
Sammamish, Wa U.S.
Post Number: 55
I have a space that is about 5" by 12" and can put either (1) 5X7 Alpine Type S or (2) 4" Alpine Type S speakers. What are your guys opinions on this? ill have a sub so i want goos SQ and dont care about bass with these speakers.
Username: Riebread77
Post Number: 324
2 4" speakers...as long as you have a larger midbass (6.5")...if you don't, then I'd go with 5x7
Sammamish, Wa U.S.
Post Number: 57
Well its going in a boat and there will be a bazooka tube fairly close to it, and the 6.5 will be about 3 feet away from the (2) 4" or the 5X7....so do you think that is close enough for (2) 4" or will i have to go with 1 5X7?
Sammamish, Wa U.S.
Post Number: 66
anyone have an opinion on this? help is greatly appreciated!
Sammamish, Wa U.S.
Post Number: 77
come on guys, i really need your opinions, i cant find a place around me with any 4" type S's so i need your guys input. remember its going in a boat along with 6.5's up front and a Bazooka tube in the middle. thanks
