Panasonic NVGS11 with Macos
Hi I purchased aPanasonic NVGS11 on Gibralter and was informed it would work with my Mac
supplied CD only has Windows drivers, anyone know wher i can get drivers for mac os or another way round the problem.
Thanks in advance
GT
Ben BP
What you need is a firewire cable that you can get from pretty much any computer or electronics store, and the mac will do the rest for you. If you are importing footage using iMovie onto a drive that has vile vault enabled, the video will jump. So the way to get around that is to import into the users folder that isn't encrypted.
Hope this helps you.
